Get body from Cut List
Question asked by Samantha Szkirpan on Jun 9, 2017
Latest reply on Jun 9, 2017 by Samantha Szkirpan
Hello
I am using VBA to program this macro.
I am trying to navigate the feature tree of a part that has a cut list folder. This folder contains a subweldments folder which contains more cut list folders which each contain what I believe are solid bodies. What I want to do is access the solid bodies in these cut list folders and save them as a parasolid. However I am running into an issue accessing the bodies and I'm not sure what I am doing wrong.
Here is my code, and I would appreciate any help.
Sub weldments()
    Dim swselObject As Object
    Dim swEnt As SldWorks.Entity
    Dim modelName As String
    Dim material As String
    Dim featName As String
    Dim subName As String
    Dim sub2Name As String
    Dim sub3name As String
    Dim bodyCount As Integer
    Dim swFeat As SldWorks.Feature
    Dim subFeat As SldWorks.Feature
    Dim sub2Feat As SldWorks.Feature
    Dim sub3Feat As Object
    Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Dim dash As String
    Set swModel = swApp.ActiveDoc
    modelName = swModel.GetTitle
    boolstatus = swModel.Extension.SelectByID2("Description", "SUBWELDFOLDER", 0, 0, 0, False, 0, Nothing, 0)
    Set swFeat = swSelMgr.GetSelectedObject(1)
    featName = swFeat.Name
    Set subFeat = swFeat.GetFirstSubFeature
    subName = subFeat.Name
    If subFeat.Name = "Sub-weldment1" Then
        Set sub2Feat = subFeat.GetFirstSubFeature
        sub2Name = sub2Feat.GetTypeName
        Do While Not subFeat Is Nothing
        If sub2Feat.Name = "Cut-List-Item2" Then
            Set swCustPropMgr = sub2Feat.CustomPropertyManager
            swCustPropMgr.Get4 "DASH", False, Empty, dash
            swCustPropMgr.Get4 "MATERIAL", False, Empty, material
            Dim folder As SldWorks.bodyFolder
            Set folder = sub2Feat.GetSpecificFeature2
           sub3Feat = sub2Feat.GetBodies
