I have Visualize Professional 2017 SP3. I am doing an animation of an exploded view of an assembly.
I would like to have a couple of configurations to show my client. For example, change the explode start-stop times to show different elapsed times. And different camera animations.
I did the "base" animation, then created a new configuration (with copy option). I adjusted the one of the key frames by dragging it on the time line.
But when I went back to the base configuration, that change was there too.
Does that mean Configurations don't apply to animations?
So I will need to copy this project and modify it?
Or can I duplicate an animation ribbon? Then suppress/hide the one I don't want in a configuration? (Same idea as configuring features in SolidWorks.)
Excellent question, Bill. Definitely shows you are an advanced user of Visualize
Animations and Configurations in Visualize have no connection with each other. I think the best way to do this is, as you described, to duplicate the animation in the Timeline and then hide/show the desired animations per each configuration. This will give you the results you're looking to achieve.
