3 Replies Latest reply on Jul 5, 2017 6:33 AM by Craig Bill
    Exclude sub-folders....  Via Exclude list.
    Craig Bill
      Good day, excuse my naivety ....
      Running SW 2016 x64 SP5.0
      I am trying to use this fantastic macro from Steve Takata to export all the embedded PDFs from our Workgroup PDM to a local folder.
      The trouble i am having is that it gets to a certain point and pings up this error (typically at the most crucial point):
      I have tried removing files from around the area that it stops with no success.
      I'm therefore wondering if someone could help me exclude this folder, at current the macro excludes root folders but to my knowledge doesn't exclude sub folders.
      This sounds like a simple task as most of the lines are there, but I have little knowledge with API.
      Assuming its this line:
      Function CreateFolderCheckForChild(proj As PDMWProject, previousPath As String)
      but cant figure out how to include the excludeList filter.
          'Uncomment this line to ignore errors and continue on silently
          'On Error Resume Next
          'Creates a connection object to the WPDM
          Set connection = CreateObject("PDMWorks.PDMWConnection")
          'Define user name, password, and server name or address
          Dim username As String
          username = "********"
          Dim password As String
          password = "********"
          Dim server As String
          server = "*********"
          Dim ret As Long
          'Login to vault using above credentials
          ret = connection.Login(username, password, server)
          If (ret <> 0) Then
              MsgBox ("Login failure. Check username, password and server.")
              'Logout of connection
              connection.Logout
              End
          Else
          'Create and instantiate project variables
          Dim singleproj As PDMWProject
          Dim project As String
          Dim excludeList(3) As String
          Dim rootDrawingsPath As String
          'Dim test() As String
          Dim item
          Dim msg
          'alldocs is a collection of *all* vault documents
          Set alldocs = connection.Documents
          'allproj is a collection of *all* vault projects
          Set allproj = connection.Projects
          'excludeList is an array of strings of root level project names to exclude
          excludeList(0) = "Trash"
          excludeList(1) = "WIP"
          excludeList(2) = "Library Components"
          'Enter the path where the PDF directory tree should begin
          rootDrawingsPath = "C:\Drawings"
          'If the root path does not exist it will be created
          'NOTE: MkDir will only create the final directory if it does not exist.
          'It will not nest multiple directories in one operation.
          If Dir(rootDrawingsPath, vbDirectory) = "" Then
              MkDir (rootDrawingsPath)
          'Iterate through each project in the allproj collection.
          'If the project does not have a parent, then it is a root level
          'project in the vault.
          For Each singleproj In allproj
              If singleproj.Parent Is Nothing Then
              'test = Filter(excludeList, singleproj.Name)
                  If UBound(Filter(excludeList, singleproj.Name)) = -1 Then
                      ret = CreateFolderCheckForChild(singleproj, rootDrawingsPath)
          Next
          connection.Logout
      'This function is the meat of the program.  This function will call itself
      'as it iterates through the vault.  There is some optimization that should
      'be done here in order to limit the number of variable that are created
      'at each level and are held in memory until exit.  However, some of these
      'variables must not be global because I am relying on them remaining the
      'same after return from a nested call.
          'Create new path using "previousPath" and appending the project name
          Dim thisPath As String
          thisPath = previousPath + "\" + proj.Name
          'If the new directory does not exsit, then create it
          If Dir(thisPath, vbDirectory) = "" Then
              MkDir (thisPath)
      Any help would be massively appreciated.
        • Re: Exclude sub-folders....  Via Exclude list.
          Andreas Killer
          I don't have PDM, so I don't know what happens... but why not use an error handler and catch the error?
          In that function, add the line
            On Error GoTo Errorhandler
          as first line and this lines
            '!!AK-15.06.17 begin
            Exit Function
          Errorhandler:
            If Err.Source = "" Then Err.Source = Application.Name
            Debug.Print "Source     : " & Err.Source
            Debug.Print "Error      : " & Err.Number
            Debug.Print "Description: " & Err.Description
            If MsgBox("Error " & Err.Number & ": " & vbNewLine & vbNewLine & _
                Err.Description & vbNewLine & vbNewLine & _
                "Enter debug mode?", vbOKCancel + vbDefaultButton2, Err.Source) = vbOK Then
              Stop 'Press F8 twice
              Resume
          '!!AK-15.06.17 end
          directly before the line
            End Function
          Hope that helps.
          Andreas.
              Craig Bill
              Hello Andreas,
              Thank you for the information and support.
              Sorry for the delay but I've been on annual leave, just a quick update.....
              I have put the lines you said "On Error GoTo Errorhandler"  under the line "Function CreateFolderCheckForChild(...."
              Also the other lines directly before End function.
              On 1st run it came back with the same issue, solidwokrs throwing up " Unknown Error ... ", then if you try to stop or pause VBA it crashes solidwokrs.
              This lead me to belive its not that part of the process, maybe more along the lines of the renaming the PDF Files:
              "    'Iterate through all results
                  Dim filename
                  For Each result In results
                      'debug line to display each result
                      'msg = MsgBox(result.Name, vbCritical)
                      'If the document has an embedded PDF, then...
                      If result.Document.HasPDF <> 0 Then
                          'Create the new filename, deleting ".slddrw", inserting separator "_" and the revision
                          'filename = thisPath & "\" & Replace(result.Name, ".SLDDRW", "") & "_" & result.Revision & ".pdf"
                          'Check to see if the target file name already exists.  If so then skip file creation.
                          'If Dir(filename) = "" Then
                              'Save out the embedded pdf to the path
                              'NOTE: this will save "filename.SLDDRW.pdf"
                              result.Document.SaveAsPDF (thisPath)
                              'Rename the file saved above to the target filename
                              'Name thisPath & "\" & result.Name & ".pdf" As filename
                     'End If"
              ^^ SO I TABBED OUT THESE LINES ^^
              Still seems to be working, without errors, so fingers crossed it was a renaming issue.....
              Craig Bill
              Update / Solution.....
              Managed to find where the export was stopping.... it stops on "(archived)" documents, as with open checkout it kick back an error as it is archived.
              (Note our archived documents seem to appear anywhere rather than isolated in an archive folder..)
              Workaround....
              Rather than trying to exclude specific folders through the macro, i setup a new PDM Login and removed any access for said  folders.
              This helped to some extent but there appeared to still be some archive documents scattered about the vault, so as the export function stopped i was able to locate archived documents to remove or restore as necessary.
              Probably not the most technical or workarounds but i learnt enough to get by, once setup & sorted new exports should be seamless.
              Hope this helps.
