I am confused how to use routing with valves that have built in compression fittings. It appears that all routes start with a fitting but in this case, the fitting is part of the component. I used Routing Library manager to modify a component defining R points and C points. This worked but it does not allow me to first mate the component into the assembly before doing the routing. I also tried creating a ferrule which I thought could be added to the component to start the route. The ferrule I created works but it does not snap in-line to the valve. There must be an easier way to do this. Any ideas?
David,
Have you thought about creating a ghost part, a part that has no other use then to be used to start a routing.
That part needs all the needed information, Rpoint, Cpoint + all data needed to determine the tubing itself (in other words diameter, material, DN, whatever is needed to select the pipe/tube that needs to be connected to it.)
That way you can start the route with a fitting that will select what tube your route will be.
Have a nice one
Peter
