Hi Guys,
I am trying to update PDM client but not successful after clicking the Update button.
I tried using the manual method to upgrade the SolidWorks explorer to 2014 SP5 by running the setup.exe under the swexplorer sub folder. After doing the upgrade the Build number is 0077 and I am still not able to login to the vault.
Kindly advise.
You need to find out what version your PDMWorks Workgroup is at and then update to that same version. I don't recall if that Update button will install the correct version, but I would start with your server version first and then go from there. Open your VaultAdmin tool and hit the About button on the login screen to get the version info.
