I have four folders
AA
BB
CC
DD
There are different parts in those folders. I need to sort the parts in different folder in different ways.
Is there any way that I can know what part is in which folder.
I have four folders
AA
BB
CC
DD
I was working on a similar task a couple weeks ago (sorting components in a folder). The conclusion that I came to was that it is easier to dissolve (delete) all folders, re-create them, and then insert the components. I found this approach easier to implement because one of the folder insertion methods takes an array of swComponents and arranges in the same order that they appear in that array.
Detect if Assembly Component is in a folder
In my case, the folders were instantiated by a "vendor" property and then some other characteristics like reference models or in-house custom parts. Some of those things were cut out of the attached TreeOrganizer_v04a for public consumption. It isn't well commented but the function names are pretty descriptive so you should get an idea for what to change to get the behavior you want.
When I was working on the TreeOrganizer, I came across the sortPartNumbers macro (also attached). It takes a different approach but appears to be faster than my method and more direct. Unfortunately, I don't know who to credit that macro to. I'm pretty sure I found it on this forum.
Sure. You can traverse the feature tree with something like this. Mostly from the top of my head:
Sub PrintFeatureTypes()
dim swApp as SldWorks.SldWorks
dim swModel as ModelDoc2
Dim swFeat as Feature
Set swModel = swApp.ActiveDoc
Set swFeat = swModel.FirstFeature
While Not swFeat Is Nothing
Debug.Print swFeat.GetTypeName2
Set swFeat = swFeat.GetNextFeature
Wend
You'll see that it will print a 'folder' type and an 'end folder' type. I don't remember the exact phrasing, but it's pretty clear when you see it.
