3 Replies Latest reply on Jun 7, 2017 2:03 PM by Peter Brinkhuis
    Vertex in sldprt → drawing point in slddrw
    Yong Ning
      vertex in sldprt
      Hope, drawing a point in slddrw
      follow code, drawing a point  is error.
      Private Sub del()
          Dim SwSelMgr As SelectionMgr, SwMathUtil As MathUtility
          Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
              Set SwApp = Application.SldWorks
              Set SwModel = SwApp.ActiveDoc
              Set SwMathUtil = SwApp.GetMathUtility
          Dim SwDraw As DrawingDoc
              Set SwDraw = SwModel
          Dim SwView As View
              Set SwView = SwDraw.GetFirstView
              Set SwView = SwView.GetNextView
              Set SwModel = SwView.ReferencedDocument
              Set SwSelMgr = SwModel.SelectionManager
          Dim SwVertex As Vertex
              Set SwVertex = SwSelMgr.GetSelectedObject5(1)
          Dim SwMathPt As MathPoint, Pt(2)
              With SwVertex
                  Debug.Print .GetPoint(0), .GetPoint(1), .GetPoint(2)
                  Pt(0) = .GetPoint(0)
                  Pt(1) = .GetPoint(1)
                  Pt(2) = .GetPoint(2)
              End With
              Set SwMathPt = SwMathUtil.CreatePoint(Pt)
              With SwMathPt
                  Debug.Print .ArrayData(0), .ArrayData(1), .ArrayData(2)
              End With
              tmp = SwView.SelectEntity(SwVertex, True)
          Dim vOutLine
              vOutLine = SwView.GetOutline
          Dim SwXForm As MathTransform
              Set SwXForm = SwView.ModelToViewTransform
          Dim SwViewPt As MathPoint
              Set SwViewPt = SwMathPt.MultiplyTransform(SwXForm)
          Dim SkPt As SketchPoint
          Dim Xx As Double, Yy As Double, Zz As Double
              With SwViewPt
                  Xx = .ArrayData(0)
                  Yy = .ArrayData(1)
                  Zz = .ArrayData(2)
              End With
          Dim oScale
              oScale = 1 / SwView.ScaleDecimal
              Xx = Xx * oScale
              Yy = Yy * oScale
              Zz = Zz * oScale
              Xx = vOutLine(0) + Xx
              Yy = vOutLine(1) + Yy
              Set SkPt = SwDraw.CreatePoint2(Xx, Yy, Zz)
              Stop
      how to get coordinates of selected vertexes on ... | SOLIDWORKS Forums  https://forum.solidworks.com/message/141098#141098#141098
      Dim swMathUtils As SldWorks.MathUtility
      Dim swXform As SldWorks.MathTransform
      Dim swMathPt As SldWorks.MathPoint
      Set swMathUtils = swApp.GetMathUtility
      Set swXform = swView.ModelToViewTransform
      Set swMathPt = swMathUtils.CreatePoint(swVertex.GetPoint())
      Set swMathPt = swMathPt.MultiplyTransform(swXform)
      'Now the coordinates converted to drawing space
      Debug.Print swMathPt.ArrayData(0) & "; " & swMathPt.ArrayData(1)
      Private Sub del20170609()
          Dim SwDispDim As DisplayDimension, SwAnn As Annotation
              Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
              Set SwAnn = SwDispDim.GetAnnotation
          Dim Ss, Ss1
              With SwAnn
                  Ss = .GetAttachedEntities
                  Ss1 = .GetAttachedEntityTypes
              End With
          Dim SkPt As SketchPoint, PtArr(2) As Double
              Set SkPt = Ss(0)
              With SkPt
                  Debug.Print .X, .Y, .Z
                  PtArr(0) = .X
                  PtArr(1) = .Y
              End With
              Stop
          Dim SwView As View, vPos
              vPos = SwView.Position
          Dim SwMathUtil As SldWorks.MathUtility
          Dim SwXForm As SldWorks.MathTransform
          Dim SwMathPt As SldWorks.MathPoint
              Set SwMathPt = SwMathUtil.CreatePoint(PtArr)
              Set SwMathPt = SwMathPt.MultiplyTransform(SwXForm)
          Dim Xx, Yy, oScale
              With SwMathPt
                  Xx = .ArrayData(0) * oScale + vPos(0)
                  Yy = .ArrayData(1) * oScale + vPos(1)
              End With
              Stop
              Set SkPt = SwModel.CreatePoint2(Xx, Yy, 0)
      Private Sub del201706102()
          Dim SwMathUtil As MathUtility
          Dim SwView As View, Ss, PtArr
          Dim SwDispDim As DisplayDimension, SwDim As Dimension
              Do While Not SwView Is Nothing
                  Set SwDispDim = SwView.GetFirstDisplayDimension
                  Do While Not SwDispDim Is Nothing
                      PtArr = retuDimMathPt(SwModel, SwMathUtil, SwView, SwDispDim)
                      Set SwDispDim = SwDispDim.GetNext
                  Loop
              Loop
      Function retuDimMathPt(SwModel As ModelDoc2, SwMathUtil As MathUtility, SwView As View, SwDispDim As DisplayDimension)
          Dim SwDim As Dimension, SwAnn As Annotation
              With SwDispDim
                   Set SwDim = .GetDimension
                   Debug.Print SwDim.FullName
                   Set SwAnn = .GetAnnotation
                   SwAnn.Select False
              End With
          Dim mPt As MathPoint, Pt(2) As Double
              With SwDim
                  Ss = SwAnn.GetPosition
                  For ii = 0 To 2
                      Debug.Print Round(Ss(ii), 4),
                  Next ii
                  Xx = Ss(0)
                  Yy = Ss(1)
                  Xx = Xx / SwView.ScaleDecimal
                  Yy = Yy / SwView.ScaleDecimal
                  Debug.Print
                  Stop
                  Ss = .ReferencePoints
                  For ii = 0 To 2
                     Set mPt = Ss(ii)
                     Set mPt = mPt.MultiplyTransform(SwXForm)
                     With mPt
                         Xx = .ArrayData(0)
                         Yy = .ArrayData(1)
                         Debug.Print ii, Xx, Yy
                     End With               ''
                  Next ii
              End With
      End Function
        • Re: Vertex in sldprt → drawing point in slddrw
          Peter Brinkhuis
          With coordinate system do you use in the drawing, the global one or the one of the view?
              Yong Ning
              Thanks for your reply, can give a small program code
              Public Sub GetEndPoints()
              Dim swApp, Part, SelMgr As Object
              ' Face object
              Dim faceObj As Object
              ' Array of edge objects
              Dim edgeList As Variant
              Dim edgeCount As Long
              ' Edge object
              Dim edgeObj As Object
              ' Vertex objects
              Dim startVertexObj As Object
              Dim endVertexObj As Object
              ' Edge startpoint and endpoint arrays
              Dim startPt As Variant
              Dim endPt As Variant
              ' Use the active document
              Set Part = swApp.ActiveDoc
              ' Setup to handle user selections
              Set SelMgr = Part.SelectionManager
              ' If no selection made, return an error
              If (SelMgr.GetSelectedObjectCount = 0) Then
              swApp.SendMsgToUser ("Select a face first...")
              ' Otherwise, continue
              Else
              If (SelMgr.GetSelectedObjectType(1) <> 2) Then
              swApp.SendMsgToUser ("Must select a face")
              Exit Sub
              ' Get the selected Face object
              Set faceObj = SelMgr.GetSelectedObject5(1)
              ' Get edge count from the face
              edgeCount = faceObj.GetEdgeCount
              ' Get all edges from the face
              edgeList = faceObj.GetEdges
              ' For each edge
              For i = 0 To (edgeCount - 1)
              Set edgeObj = edgeList(i)
              ' Get the "Start" vertex
              Set startVertexObj = edgeObj.GetStartVertex
              ' Get the "End" vertex
              Set endVertexObj = edgeObj.GetEndVertex
              ' Define message
              Msg = "Edge points: " + Chr(10)
              If (Not startVertexObj Is Nothing) Then
              ' Get the xyz vertex location
              startPt = startVertexObj.GetPoint
              Msg = Msg + Str$(startPt(0)) + "," + Str$(startPt(1)) + "," + Str$(startPt(2)) + Chr(10)
              If (Not endVertexObj Is Nothing) Then
              endPt = endVertexObj.GetPoint
              Msg = Msg + Str$(endPt(0)) + "," + Str$(endPt(1)) + "," + Str$(endPt(2))
              ' OK Button only
              Style = vbOKOnly
              ' Define title
              Title = "Vertex Info"
              ' Display message to user
              Call MsgBox(Msg, Style, Title)
              Next
              Sub main1()
                  Dim swApp                       As SldWorks.SldWorks
                  Dim swModel                     As SldWorks.ModelDoc2
                  Dim swSelMgr                    As SldWorks.SelectionMgr
                  Dim swVert                      As SldWorks.Vertex
                  Dim vEdgeArr                    As Variant
                  Dim vEdge                       As Variant
                  Dim swEdge                      As SldWorks.Edge
                  Dim swEnt                       As SldWorks.Entity
                  Dim bRet                        As Boolean
                  Set swModel = swApp.ActiveDoc
                  Set swVert = swSelMgr.GetSelectedObject5(1)
                  swModel.ClearSelection2 True
                  vEdgeArr = swVert.GetEdges
                  For Each vEdge In vEdgeArr
                      Set swEdge = vEdge
                      Set swEnt = swEdge
                      bRet = swEnt.Select4(True, Nothing): Debug.Assert bRet
                  Next vEdge
              Sub main2()
              Dim Part As SldWorks.PartDoc
              Dim Body As SldWorks.Body2
              Dim Edge As SldWorks.Edge
              Dim Vertex As SldWorks.Vertex
              Dim Bodyarr As Variant
              Dim vbody As Variant
              Dim Edgearr As Variant
              Dim idx As Long
              Dim vobj As Variant
              Dim crgb As Long
              Bodyarr = Part.GetBodies2(swSolidBody, True)
              For Each vbody In Bodyarr
                  Set Body = vbody
                  Edgearr = Body.GetEdges
                  idx = 0
                  For Each vobj In Edgearr
                      Set Edge = vobj
                      Set Vertex = Edge.GetStartVertex
                      Select Case CInt(idx Mod 8)
                      Case 0
                         crgb = RGB(0, 0, 0)
                      Case 1
                         crgb = RGB(0, 0, 255)
                      Case 2
                         crgb = RGB(0, 255, 0)
                      Case 3
                         crgb = RGB(0, 255, 255)
                      Case 4
                         crgb = RGB(255, 0, 0)
                      Case 5
                         crgb = RGB(255, 0, 255)
                      Case 6
                         crgb = RGB(255, 255, 0)
                      Case 7
                         crgb = RGB(255, 255, 255)
                  End Select
                  idx = idx + 1
                  Vertex.Display Part, crgb, 1, True
                 Next
              Next
              2010 SOLIDWORKS API Help - Get Edges for Vertex Example (VBA)  http://help.solidworks.com/2010/english/api/sldworksapi/get_edges_for_vertex_example_vb.htm
              2010 SOLIDWORKS API Help - Get Vertex Example (VBA)  http://help.solidworks.com/2010/english/api/sldworksapi/get_vertex_example_vb.htm
              2010 SOLIDWORKS API Help - Display Vertices Example (VBA)  http://help.solidworks.com/2010/english/api/sldworksapi/display_vertices_example_vb.htm
              Private Sub del201706101()
                      'Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
                      Set SwDim = SwModel.Parameter("D1@Extrude1@a.Part")
                  Dim Ss, Ss1
                      'Debug.Print SwDispDim.GetDimension.FullName
                      With SwDim
                          For ii = 0 To 2
                             Set mPt = Ss(ii)
                             With mPt
                             End With
                          Next ii
                      End With
                      Set mPt = Ss(1)
                      SwModel.ClearSelection2 True
                  Dim SwView As View
                  Dim MathPt As MathPoint, Pt(2) As Double
                      With mPt
                          Pt(0) = .ArrayData(0)
                          Pt(1) = .ArrayData(1)
                      End With
                      Set MathPt = SwMathUtil.CreatePoint(Pt)
                      Set MathPt = mPt.MultiplyTransform(SwXForm)
                  Dim Xx, Yy, oScale
                      With MathPt
                          Xx = .ArrayData(0)
                          Yy = .ArrayData(1)
                      End With
                  Peter Brinkhuis
                  You can try this:
                  • Select a drawing view and insert a sketch point
                  • Select the sheet and insert a sketch point
                  The point will show up at different locations. To make sure your sketch item is placed correctly, you need to select the correct drawing view first. The sheet itself is considered by SolidWorks as the first drawing view. When you have the drawingDoc object, GetFirstView will get you the sheet object. After that you can use GetNextView on the view object to get the first real view.
