Make all the parts, sub assemblies and parts in sub-assemblies in the main assembly as virtual components through API
Question asked by Sachin Murigesh on Jun 6, 2017
Latest reply on Jun 7, 2017 by Sachin Murigesh
Hi API gurus,
I was creating this tiny VBA code that transverse through all the parts in assembly (Current active, opened assembly) and make them as virtual components.
If there is sub assembly inside the main assembly, it'll make it as virtual component and the loop through it to make its parts virtual.
I was able to make the pars and sub-assemblies in first layer as virtual components.
I'm having having trouble to set the components in layer 2,3++ that belong to sub-assemblies as virtual components.
But my function can loop through it.
Any help will be highly appreciated
Option Explicit
Dim swAssembly As SldWorks.AssemblyDoc
Dim swConfig As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim n As Long
Sub TraverseComponent(swComp As SldWorks.Component2)
    Dim vChildComp As Variant
    Dim swChildComp As SldWorks.Component2
    Dim swCompModel  As ModelDoc2
    Dim swCompConfig As SldWorks.Configuration
    Dim sPadStr As String
    Dim i As Long
    Dim stat As Boolean
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
    Set swChildComp = vChildComp(i)
       Set swCompModel = swChildComp.GetModelDoc2
       'Debug.Print swChildComp.Name
       If swCompModel.Extension.ToolboxPartType = 0 Then
            stat = swChildComp.MakeVirtual
       TraverseComponent swChildComp
    Next i
    Dim swConf As SldWorks.Configuration
    Dim i As Long
    Set swModel = swApp.ActiveDoc
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    TraverseComponent swRootComp
