5 Replies Latest reply on Jun 6, 2017 4:35 PM by Matt Kane
    Macro to rename all sketches in part
    Matt Kane
      Hi.
      I am attempting to write a macro to rename all sketches in a part in order (to sooth my OCD ).
      The code below works for the most part. (I'm sure it is quite sloppy, feel free to suggest improvements)
      The problem I am having is that some sketches (ones that belong to Extruded Cuts etc) seem to be both features and subfeatures and are being renamed twice.
      I can't think of a way to prevent this. Could someone please offer a suggestion.
      I have also included a sample part.
      Regards Matt
          Set swPart = swApp.ActiveDoc
          Set swFeat = swPart.FirstFeature
          SketchCount = 1
          Do While Not swFeat Is Nothing
              newSketchName = "Sketch" & SketchCount
                  If swFeat.GetTypeName2 = "ProfileFeature" Then
                      If swPart.Extension.SelectByID2(newSketchName, "SKETCH", 0, 0, 0, False, 0, Nothing, 0) = True Then
                          Set tempFeat = swPart.FeatureByName(newSketchName)
                          tempFeat.Name = tempFeat.Name & "temp"
                  swFeat.Name = newSketchName
                  SketchCount = SketchCount + 1
                  Else
                      Set swsubFeat = swFeat.GetFirstSubFeature
                      Do While Not swsubFeat Is Nothing
                      If swsubFeat.GetTypeName2 = "ProfileFeature" Then
                      swsubFeat.Name = newSketchName
                      Set swsubFeat = swsubFeat.GetNextSubFeature
                      Loop
                  Set swFeat = swFeat.GetNextFeature
          Loop
        • Re: Macro to rename all sketches in part
          Josh Brady
          I think the simplest way for you to do this would be to run through the entire thing twice.  Once would rename every sketch to "TempSketch" plus a number.  Then, on your second run through, check to see if the sketch name starts with "TempSketch".  If it does, rename it to Sketch plus your number.  If not, don't rename.  Not efficient, but neither is the entire concept of this exercise.
              Set swfeat = swPart.FirstFeature
              SketchCount = 1
              'First rename everything.
              Do While Not swfeat Is Nothing
                  newSketchName = "TempSketch" & SketchCount
                  If swfeat.GetTypeName2 = "ProfileFeature" Then
                      swfeat.Name = newSketchName
                  Else
                      Set swsubfeat = swfeat.GetFirstSubFeature
                      Do While Not swsubfeat Is Nothing
                          If swsubfeat.GetTypeName2 = "ProfileFeature" Then
                              swsubfeat.Name = newSketchName
                          Set swsubfeat = swsubfeat.GetNextSubFeature
                      Loop
                  Set swfeat = swfeat.GetNextFeature
              Loop
              SketchCount = 1
                      If Left(swfeat.Name, 10) = "TempSketch" Then
                  Else
                              If Left(swsubfeat.Name, 10) = "TempSketch" Then
                      Loop
              Loop
            Steve Calvert
            That's some serious CDO (OCD but in the right order)...
            Steve C
