VBA - Stacked Balloons for Toolbox Items
Question asked by Cad Admin on Jun 6, 2017
Latest reply on Jul 26, 2017 by Cad Admin
VBA Macro
Currently my company uses a stacked balloon for toolbox items.  I'm trying to create a macro that selects all balloons on a sheet then checks to see if they are a toolbox item. & if so adds a stacked balloon to the original balloons, in a specific format.
What i have so far...
  • i can select a balloon,
  • I can determine if the attached item is a toolbox item.
  • I can add a balloon in the per-determined format.
Issues..
  • I can't seem to change the value of the stacked balloon to read the "description" custom property of the detail it is ballooning.
  • selection is based off a "recorded macro"... the add-too isn't following the "user selection" it using the "recorded selection"
Future
  • I would like run this on all balloons on all sheets..without user selection of the balloons...more automatic.
Warning(LOL): Code below is a Hodge-Podge of snippets i either have found or currently use...
Option Explicit
    Dim swApp                            As SldWorks.SldWorks
    Dim swModel                         As SldWorks.ModelDoc
    Dim swSelMgr                       As SldWorks.SelectionMgr
    Dim swNote                      As SldWorks.Note
    Dim swAnn                       As SldWorks.Annotation
    Dim modelDocExt                 As SldWorks.ModelDocExtension
    Dim vAttEntArr                  As Variant
    Dim vAttEntTypeArr              As Variant
    Dim swEnt                       As SldWorks.Entity
    Dim swComp                      As SldWorks.Component
    Dim swCompModel                 As SldWorks.ModelDoc
    Dim i                           As Long
    Dim bRet                        As Boolean
    Dim ret                         As Long
    Dim boolstatus                  As Boolean
    Set swModel = swApp.ActiveDoc
    Set swNote = swSelMgr.GetSelectedObject5(1)
    Set swAnn = swNote.GetAnnotation
    Debug.Assert swNote.IsBomBalloon
    vAttEntArr = swAnn.GetAttachedEntities2: If IsEmpty(vAttEntArr) Then Exit Sub
    vAttEntTypeArr = swAnn.GetAttachedEntityTypes
    Debug.Assert UBound(vAttEntArr) = UBound(vAttEntTypeArr)
    Debug.Print "File = " & swModel.GetPathName
    Debug.Print "  Name                 = " & swAnn.GetName
    Debug.Print "    Is stacked         = " & swNote.IsStackedBalloon
    Debug.Print "    Is stacked master  = " & swNote.IsStackedBalloonMaster
    For i = 0 To UBound(vAttEntArr)
        Debug.Print "    AttEntType         = " & vAttEntTypeArr(i)
        If swSelNOTHING <> vAttEntTypeArr(i) Then
            Set swEnt = vAttEntArr(i)
            Set swComp = swEnt.GetComponent
            Set swCompModel = swComp.GetModelDoc
            Set modelDocExt = swCompModel.Extension
            ret = modelDocExt.ToolboxPartType
            Debug.Print "    AttEnt             = " & swComp.GetPathName & " <" & swComp.ReferencedConfiguration & ">"
            Debug.Print "    Toolbox part type  = " & ret
'----------------------------------------Add Balloon Code Here--------------------------------------------------
            If ret <> 0 Then
            Dim Part As Object
                Set Part = swApp.ActiveDoc
                boolstatus = Part.Extension.SelectByID2("DetailItem561@Drawing View4", "NOTE", 0.330553225698155, 0.435615531289275, 0, False, 0, Nothing, 0)
                Set swNote = Part.SelectionManager.GetSelectedObject3(1)
                boolstatus = Part.Extension.SelectByRay(0.271848815289342, 0.448482251378878, 3.97671893132383E-02, 0, 0, -1, 5.46835603808116E-04, 2, False, 0, 0)
                Dim myBalloonStack      As Object
                Dim swNote2             As Object
                If Not swNote Is Nothing Then
                   Set myBalloonStack = swNote.GetBalloonStack()
                   Set swNote2 = myBalloonStack.AddTo(swBalloonTextContent_e.swBalloonTextCustom, "Description", 1, "")
                        Dim doubleQuote As String
                        doubleQuote = Chr(34)
                        swNote2.PropertyLinkedText = "$PRPMODEL:" & doubleQuote & "Description" & doubleQuote
                        boolstatus = swNote2.SetBalloon(swBalloonStyle_e.swBS_Underline, swBalloonFit_e.swBF_Tightest)
    Next i
As always all help is appreciated...Thanks in advance
