what i'm trying to do is create flat pattern templates so that the guy's in the shop can use them to wrap round the pipe mark it and cut it to create segments that will be welded together to create 90 degree elbows. the problem i'm having is that when I flatten my models they are shorter than the actual circumference of the pipe. they all seem to come up short by about two inches
To make a wrap around you would want to set your k factor to 1 for the outside diameter. See if that helps.
