Is there any possibilities to create bounding box for all bodies?
I tried with help( Below codes). That is based on feature. Which line i want change to select all the bodies?
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeat As SldWorks.Feature
Dim swFace As SldWorks.Face2
Dim BoxFeatureArray As Variant
Dim BoxFaceArray As Variant
Dim swSketchMgr As SldWorks.SketchManager
Dim swSketchPt(8) As SldWorks.SketchPoint
Dim swSketchSeg(12) As SldWorks.SketchSegment
Dim status As Boolean
Dim errors As Long
Dim warnings As Long
Dim fileName As String
Dim swModExt As SldWorks.ModelDocExtension
Dim swBody As SldWorks.Body2
Dim sBodySelStr As String
Dim sBodyTypeSelStr As String
Dim i As Long
Dim bRet As Boolean
' Open part document
'fileName = "C:\Users\Public\Documents\SOLIDWORKS\SOLIDWORKS 2017\tutorial\api\cstick.sldprt"
'Set swModel = swApp.OpenDoc6(fileName, swDocPART, swOpenDocOptions_Silent, "", errors, warnings)
Set swModel = swApp.ActiveDoc
' Select feature
Set swModelDocExt = swModel.Extension
status = swModelDocExt.SelectByID2("Revolve1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
' Get selected feature's bounding box
Debug.Print "Feature:"
status = swFeat.GetBox(BoxFeatureArray): Debug.Assert status
Debug.Print " Pt1 = " & _
"(" & _
BoxFeatureArray(0) * 1000# & ", " & _
BoxFeatureArray(1) * 1000# & ", " & _
BoxFeatureArray(2) * 1000# & _
") mm"
Debug.Print " Pt2 = " & _
"(" & _
BoxFeatureArray(3) * 1000# & ", " & _
BoxFeatureArray(4) * 1000# & ", " & _
BoxFeatureArray(5) * 1000# & _
") mm"
swModel.Insert3DSketch2 True
swModel.SetAddToDB True
swModel.SetDisplayWhenAdded False
Set swSketchMgr = swModel.SketchManager
' Draw points at each corner of bounding box
Set swSketchPt(0) = swSketchMgr.CreatePoint(BoxFeatureArray(3), BoxFeatureArray(1), BoxFeatureArray(5))
Set swSketchPt(1) = swSketchMgr.CreatePoint(BoxFeatureArray(0), BoxFeatureArray(1), BoxFeatureArray(5))
Set swSketchPt(2) = swSketchMgr.CreatePoint(BoxFeatureArray(0), BoxFeatureArray(1), BoxFeatureArray(2))
Set swSketchPt(3) = swSketchMgr.CreatePoint(BoxFeatureArray(3), BoxFeatureArray(1), BoxFeatureArray(2))
Set swSketchPt(4) = swSketchMgr.CreatePoint(BoxFeatureArray(3), BoxFeatureArray(4), BoxFeatureArray(5))
Set swSketchPt(5) = swSketchMgr.CreatePoint(BoxFeatureArray(0), BoxFeatureArray(4), BoxFeatureArray(5))
Set swSketchPt(6) = swSketchMgr.CreatePoint(BoxFeatureArray(0), BoxFeatureArray(4), BoxFeatureArray(2))
Set swSketchPt(7) = swSketchMgr.CreatePoint(BoxFeatureArray(3), BoxFeatureArray(4), BoxFeatureArray(2))
' Now draw bounding box
Set swSketchSeg(0) = swSketchMgr.CreateLine(swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z, swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z)
Set swSketchSeg(1) = swSketchMgr.CreateLine(swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z, swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z)
Set swSketchSeg(2) = swSketchMgr.CreateLine(swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z, swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z)
Set swSketchSeg(3) = swSketchMgr.CreateLine(swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z, swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z)
Set swSketchSeg(4) = swSketchMgr.CreateLine(swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z, swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z)
Set swSketchSeg(5) = swSketchMgr.CreateLine(swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z, swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z)
Set swSketchSeg(6) = swSketchMgr.CreateLine(swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z, swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z)
Set swSketchSeg(7) = swSketchMgr.CreateLine(swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z, swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z)
Set swSketchSeg(8) = swSketchMgr.Cr
ThaeateLine(swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z, swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z)
Set swSketchSeg(9) = swSketchMgr.CreateLine(swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z, swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z)
Set swSketchSeg(10) = swSketchMgr.CreateLine(swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z, swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z)
Set swSketchSeg(11) = swSketchMgr.CreateLine(swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z, swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z)
swModel.SetDisplayWhenAdded True
swModel.SetAddToDB False
swModel.ClearSelection2 True
' Get selected face's bounding box
Thank you
You need to traverse all bodies and then use this GetBodyBox Method (IBody2) to get the corner points
