0 Replies Latest reply on Jun 5, 2017 7:32 AM by Korbi Anis
    TRANSLATE CODE FROM VB TO VBA
    Korbi Anis
      I have a code that I translated from C# to VB. I Have not an experience with VB CODE.and I would like to translate my code from VB to VBA;. someone can help me plzzzzz. I need the code to do my homowork plz.thanks
      CODE :
      Imports System.Collections.Generic
      Imports System.Text
      Imports Autodesk.Revit.Attributes
      Imports Autodesk.Revit.DB
      Imports Autodesk.Revit.UI
      Namespace Revit.SDK.Samples.HelloRevit.CS
      <Transaction(TransactionMode.Manual)> _
      Public Class Command
      Implements IExternalCommand
      Public Function Execute(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
      Dim uiDoc As UIDocument = commandData.Application.ActiveUIDocument
      Using trans As New Transaction(uiDoc.Document, "Point")
      trans.Start()
      ' Ensure you select a DividedSurface Element from the model
      For Each ele As Element In uiDoc.Selection.Elements
      Dim surface As DividedSurface = TryCast(ele, DividedSurface)
      If surface IsNot Nothing Then
      Dim opts As Options = uiDoc.Document.Application.Create.NewGeometryOptions()
      Dim geoEle As GeometryElement = surface.get_Geometry(opts)
      Dim geoElems As IEnumerator(Of GeometryObject) = geoEle.GetEnumerator()
      While geoElems.MoveNext()
      Dim geoObj As GeometryObject = TryCast(geoElems.Current, GeometryObject)
      Dim line As Line = TryCast(geoObj, Line)
      If line IsNot Nothing Then
      Dim geoNestedElems As IEnumerator(Of GeometryObject) = geoEle.GetEnumerator()
      While geoNestedElems.MoveNext()
      Dim geoObjNested As GeometryObject = TryCast(geoNestedElems.Current, GeometryObject)
      Dim nestedLine As Line = TryCast(geoObjNested, Line)
      If nestedLine IsNot Nothing Then
      ' Ensure that this line is not the same as
      ' main line
      If Not nestedLine.Equals(line) Then
      ' Create container for the
      ' intersection results array
      Dim resArray As New IntersectionResultArray()' Get the intersection result array using Intersect()
      line.Intersect(nestedLine, resArray)
      If resArray IsNot Nothing Then
      For Each res As IntersectionResult In resArray' Create a new reference point' for each intersection point
      Dim rp As ReferencePoint = uiDoc.Document.FamilyCreate.NewReferencePoint(res.XYZPoint)
      NextEnd IfEnd If
      End WhileEnd If
      End While
      Next
      trans.Commit()
      End Using
      Return Result.Succeeded
      End Function
      End Class
      End Namespace
      This code give fot all user the opportunity to cretate a reference points of lines intersections. its too useful !!! you can see the results given with C# code in the picture enclosed.Capture.JPG
