Hi Michael,
One way is to make sure the radius arrow head is positioned on the actual arc edge. I understand the arc can be very small in some cases. If it is on the arc, there will be no need for the software to thrown in an arc extension line.
However, an alternative work around,
Select all the radius dimensions you are concerned with, go the leaders tab and select the option to make it a multijog leader,
if need be, change the style of the arrow head to match those of your other dimensions.
now i can no longer see the extension arc on my radius dimension.
Before..
After..
although, personally I'd prefer to have it in there.
Hope this helps!
Kyle
Hi Michael,
Before..
After..
Hope this helps!
Kyle
