Help to translate a macro to VBA
Question asked by Korbi Anis on Jun 4, 2017
Latest reply on Jun 5, 2017 by Korbi Anis
Hi friends , I have a macro wich is used to divide surface in iso curve and after get and display all intersection points of each lines ! I have some problem to translate this macro to vba . somone can help me plz.thanks in advance
This is the macro :
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace Revit.SDK.Samples.HelloRevit.CS
  [Transaction(TransactionMode.Manual)]
  public class Command : IExternalCommand
    public Result Execute(ExternalCommandData commandData,
      ref string message,
      ElementSet elements)
      UIDocument uiDoc = commandData.Application.ActiveUIDocument;
      using (Transaction trans = new Transaction(uiDoc.Document, "Point"))
        trans.Start();
        // Ensure you select a DividedSurface Element from the model
        foreach (Element ele in uiDoc.Selection.Elements)
          DividedSurface surface = ele as DividedSurface;
          if (null != surface)
            Options opts =
              uiDoc.Document.Application.Create.NewGeometryOptions();
            GeometryElement geoEle = surface.get_Geometry(opts);
            IEnumerator<GeometryObject> geoElems =
              geoEle.GetEnumerator();
            while (geoElems.MoveNext())
              GeometryObject geoObj =
                geoElems.Current as GeometryObject;
              Line line = geoObj as Line;
              if (null != line)
                IEnumerator<GeometryObject> geoNestedElems =
                while (geoNestedElems.MoveNext())
                  GeometryObject geoObjNested =
                    geoNestedElems.Current as GeometryObject;
                  Line nestedLine = geoObjNested as Line;
                  if (null != nestedLine)
                    // Ensure that this line is not the same as
                    // main line
                    if (!nestedLine.Equals(line))
                      // Create container for the
                      // intersection results array
                      IntersectionResultArray resArray =
                        new IntersectionResultArray();
                      // Get the intersection result
                      // array using Intersect()
                      line.Intersect(nestedLine, out resArray);
                      if (null != resArray)
                        foreach (IntersectionResult res in resArray)
                          // Create a new reference point
                          // for each intersection point
                          ReferencePoint rp =
                            uiDoc.Document.FamilyCreate.
                            NewReferencePoint(res.XYZPoint);
        trans.Commit();
      return Result.Succeeded;
