I'm trying to scale a sketch in one dimension. Somehow Solidworks was doing it before and I didn't even realize this. Then Solidworks crashed and now I can't figure out how to do it.
One workaround would be to make a surface from the sketch and scale the surface.
After that, you could export and re-import the surface so you could move it to the top of the feature tree and use it as a template for restructuring your original sketch.
dimension in 2D dwg or 3D model?
