This is a tutorial. Given Spring height = 72.5mm, Two hooks are there in 200mm apart, structure for the hook is starting from where Spring height ends according to given drawing. This dimension is given 60mm.
According to my sketch it is more than 60mm. How to fix this problem?
Maha,
Taking a closer look at the PDF sketch, it looks like one side of the spring is 60mm & the other side looks longer. So would work out to be 67.5mm.
