Hi .
I have drawn 8 plates each 200 mm x200 mm with a thickness of 3 mm
They have various shaped holes cut in them
If I save them as SW part files its fine but if I save them as DWG files
to use on my laser cutter
2 of them stayed as 200 mm x 200 mm as they should but the other 6
changed to 171.689 mm x 171.689 mm .
Everything is still in the files but its as if they decided to scale themselves down
Why would it do this
why to only some of the files
why does it make all the changed ones the same size
Don
Hi Don,
How are you saving the DXFs? from frawing or part?
