Hi everyone,
Probably this question was already made, but I rely on your support on this.
I'm trying to model a cabinet luggage case, and since it is produced by vacuum forming, the pattern I have on the front surface will have be present at the side and top faces.
However I can't figure out how I should do it.
As you can see from the image the cutted indentations should keep their path to the side and top faces.
I also did a honeycomb pattern but I can't model in the curves ( the pattern and the dome don't keep up with the fillets) in side faces.
Attached I'm sending the files with which I am struggling.
How can I do this?
Thanks in advance.
You can project the pattern to the curved part using the Split Line Curve feature.
