2 Replies Latest reply on Jun 2, 2017 5:51 AM by Yong Ning
    GetAttachedEntities
    Yong Ning
      follow code, create sketchpoint is x=50,y=20
      Help me, point coordinate is   x=25,y = 10
      Private Sub del20170601()
          Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
              Set SwApp = Application.SldWorks
              Set SwModel = SwApp.ActiveDoc
          Dim SwDraw As DrawingDoc
              Set SwDraw = SwModel
          Dim Xx, Yy
          Dim SwSelMgr As SelectionMgr
              Set SwSelMgr = SwModel.SelectionManager
          Dim SwDim As Dimension
          Dim SwDispDim As DisplayDimension, SwAnn As Annotation
          Dim vEntArr, vEntTypeArr
          Dim SkPt As SketchPoint
              Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
              If Not SwDispDim Is Nothing Then
                   Set SwAnn = SwDispDim.GetAnnotation
                   vEntArr = SwAnn.GetAttachedEntities
                   vEntTypeArr = SwAnn.GetAttachedEntityTypes
                      For jj = 0 To UBound(vEntTypeArr)
                              Set SwPt = vEntArr(jj)
                              With SwPt
                                  Xx = .X
                                  Yy = .Y
                                  Set SkPt = SwModel.CreatePoint2(Xx, Yy, 0)'????????
                              End With
                      Next jj
        • Re: GetAttachedEntities
          Scott Stuart
          Just a guess, but do you have to factor in the view scale?
            Yong Ning
            Dim SwModel                 As SldWorks.ModelDoc2
            Dim SwDraw                  As SldWorks.DrawingDoc
            Dim SwView                  As SldWorks.View
            Dim SwDispDim               As SldWorks.DisplayDimension
            Dim SwDim                   As SldWorks.Dimension
            Dim SwAnn                   As SldWorks.Annotation
            Dim swDisplayDimension      As SldWorks.DisplayDimension
                Set SwView = SwDraw.GetFirstView
                While Not SwView Is Nothing
                    Set SwAnn = SwView.GetFirstAnnotation3
                    While Not SwAnn Is Nothing
                        Debug.Print " "
                        Debug.Print "Annotation name = " & SwAnn.GetName
                        If SwAnn.GetType = swAnnotationType_e.swDisplayDimension Then
                            Debug.Print "  Is a display dimension? True"
                            Set swDisplayDimension = SwAnn.GetSpecificAnnotation
                            Select Case (swDisplayDimension.Type2)
                               Case swDimensionType_e.swOrdinateDimension
            Debug.Print "  Display dimension type = " & GetOrientation(swDisplayDimension) & " ordinate and its subordinates"
                               Case swDimensionType_e.swLinearDimension
            Debug.Print "  Display dimension type = " & GetOrientation(swDisplayDimension) & " linear"
                               Case swDimensionType_e.swAngularDimension
            Debug.Print "  Display dimension type  = angular"
                               Case swDimensionType_e.swArcLengthDimension
            Debug.Print "  Display dimension type = arc length"
                               Case swDimensionType_e.swRadialDimension
            Debug.Print "  Display dimension type = radial"
                               Case swDimensionType_e.swDiameterDimension
            Debug.Print "  Display dimension type = diameter"
                               Case swDimensionType_e.swHorOrdinateDimension
            Debug.Print "  Display dimension type = horizontal ordinate"
                               Case swDimensionType_e.swVertOrdinateDimension
            Debug.Print "  Display dimension type = vertical ordinate"
                               Case swDimensionType_e.swZAxisDimension
            Debug.Print "  Display dimension type = z-axis"
                               Case swDimensionType_e.swChamferDimension
            Debug.Print "  Display dimension type = chamfer dimension"
                               Case swDimensionType_e.swHorLinearDimension
            Debug.Print "  Display dimension type = horizontal linear"
                               Case swDimensionType_e.swVertLinearDimension
            Debug.Print "  Display dimension type = vertical linear"
                               Case swDimensionType_e.swScalarDimension
            Debug.Print "  Display dimension type = scalar"
                               Case Else
            Debug.Print "  Display dimension type = unknown"
                            End Select
                        Set SwAnn = SwAnn.GetNext3
                    Wend
                    Set SwView = SwView.GetNextView
                Wend
            Function GetOrientation(swDisplayDimension As DisplayDimension) As String
                Set SwDim = swDisplayDimension.GetDimension '2(0)
                Dim swMathVec As SldWorks.MathVector
                Dim vDir As Variant
                GetOrientation = ""
                Set swMathVec = SwDim.DimensionLineDirection
                vDir = swMathVec.ArrayData
                If IsCollinear(vDir(0), 1) And IsCollinear(vDir(1), 0) Then
                    GetOrientation = "horizontal"
                ElseIf IsCollinear(vDir(1), 1) And IsCollinear(vDir(0), 0) Then
                    GetOrientation = "vertical"
            End Function
            Function IsCollinear(val As Variant, vector As Double) As Boolean
                Const TOL = 0.00000001
                IsCollinear = Abs(Abs(val) - Abs(vector)) < TOL
            End Function
            How to determine the vertical size, or horizont... | SOLIDWORKS Forums  https://forum.solidworks.com/message/721529
