Measure Tool Returns Erroneous Results
Question asked by Bruce Secovich on May 31, 2017
Latest reply on Jun 2, 2017 by Bruce Secovich
I was adjusting the placement of a mating hole on a part in an assembly and when I measured the difference in locations to the threaded hole to adjust my sketch dimension, this is what I get:
The only correct number is the Distance between circle centers. Thank goodness all the other numbers are obviously bogus or I might have used the Delta Y (colinear with the Distance between circle centers in this case) which is what I expected to use in this case.  These are the only two edges selected as you can see in the dialog box.
