swModel.Extension.RenameDocument not working properly
Question asked by Michael Chamerski on May 29, 2017
Latest reply on Jun 20, 2017 by Michael Chamerski
Hi all -
I'm in a dilemma here. I ran a piece of code that worked flawlessly and renamed components and configurations in assemblies. As soon as I added another segment to unsuppress all features, the entire thing stopped working. I removed the portion I added, and to my surprise (or the lack thereof), the script still wasn't working properly. I'm not receiving any errors, and the Replace function seems to be working just fine (swModel.GetTitle properly obtains document title, but swModel.Extension.RenameDocument fails to do anything). Would greatly appreciate some guidance!
Function configRename(swModel As SldWorks.ModelDoc2) As Boolean
  ' Declare variables path, FileName, and Description to default state String
    Dim path As String, FileName As String, FileOld As String, Description As String
    Dim ConfigName As String
    Dim ConfigOld As String
    FileOld = swModel.GetTitle
    ' swApp.SendMsgToUser(FileOld)
    FileName = Replace(FileOld, "@", "(a)")
    FileName = Replace(FileName, "<", "(")
    FileName = Replace(FileName, ">", ")")
    FileName = Replace(FileName, "$", "(S)")
    FileName = Replace(FileName, "%", "_")
    FileName = Replace(FileName, "\", "_")
    FileName = Replace(FileName, "*", "_")
    FileName = Replace(FileName, ":", "_")
    FileName = Replace(FileName, Chr(34), Chr(34) + " (2x ')")
    FileName = Replace(FileName, "?", "_")
    FileName = Replace(FileName, "|", "_")
    FileName = Replace(FileName, ",", "_")
    FileName = Replace(FileName, "{", "(")
    FileName = Replace(FileName, "}", ")")
    FileName = Replace(FileName, "#", "(_)")
    FileName = Replace(FileName, "&", "_")
        ' swApp.SendMsgToUser (FileName)
    swModel.Extension.RenameDocument FileName
    If FileName = FileOld Then
        'Do nothing.
    Else
        ModCount = ModCount + 1
swModel.ForceRebuild3 True
You can see I commented out some debugging lines. When running these, I get the following:
swApp.SendMsgToUser (FileOld) ---> "MT1_Test_{1}"
swApp.SendMsgToUser (FileName) ---> "MT1_Test_(1)"
As you can see, FileName is the proper result I'm looking for, but after running the entire macro I'm still left with "{1}" rather than "(1)". For whatever reason this worked  a couple hours ago. Now I can't wrap my head around it anymore. I've attached the entire script I have (yes it's a mess at the moment).
Thanks in advance
Michael
