I have a Control Panel with a logo with a frame around it, some letters positive, some negative. It's a "double nested extrusion" that I made myself a several months ago and thought, wow this is a great new feature because always before I had to make it in pieces.
I made a copy to work on the next rev. When I took out part of the lettering in Boss-Extrude2 the logo caused the extrusion to fail with a message about "Double Nested Extrusion". Backed up and removed one line of lettering at a time closing the sketch after each one and discovered deleting "240VAC..." caused the logo to fail. Why?
I have attached a "Test" file with "240VAC..." still in there. If you take that out (240...) the extrusion will fail until you also take the lettering out of the logo.
jerry
