I am trying to rotate the object manipulation tool before moving the object to keep everything in perfect moving order. I tried moving the object pivot origin and rotating to the correct spot and the position changes not the orientation. Images included.
Hi Chris ,
not sure if you have tried this already but try unchecking the Absolute Checkbox at the end of the manipulation tools drop down , this should allow you to adjust the pivot.
