If I create a simple part file which is a pin, I apply a tolerance on the diameter of the circle used to extrude that solid part. Is there a way to link that tolerance to the tolerance which shows up for that diameter dimension in the drawing? It looks like the tolerance has to be redefined in the drawing. Am I missing something?
Hi Aaron,
I use "Model items" to bring tolerances from 3D model to 2D drawing. I not sure if there is a way to bring tolerances when dimensioning using "Smart Dimensioning" in 2D.
