JRJoe Rochinski22/12/2008
I've attached a screen shot of a frame for some mobile
machinery I'm analyzing. As you can see, I've cut the model along
the mid-plane and applied the symmetry constraint to all resulting
faces along the midplane. The machine is fixed at the pin
connections for each of four jacks (2 here due to symmetry) and I
have applied loads to the flat faces in 2 places as shown.
Is it incorrect to attempt to mirror a load in this way in Simulation? If this method does yield acceptable results, is the load I specify effectively doubled due to the symmetry or is the value i specify the full load applied?
