I putting together a macro that i can run on an assembly to automatically replace parts. Basically im replacing a specific named part with a identical part with a different name from a defined standards library location.
I can get the components & their configurations being used. However the "replace" is failing
my problem lies in: bRet = swAssy.ReplaceComponents2(FileName, CfgName, True, 0, True), need it to return true & im getting false
See Code Below:
Option Explicit
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim swSelComp As SldWorks.Component2
Dim swSelModel As SldWorks.ModelDoc2
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim sPadStr As String
Dim i As Long
Dim CfgName As String
Dim FileName As String
Dim bRet As Boolean
Dim nErrors As Long
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
For i = 0 To nLevel - 1
sPadStr = sPadStr + " "
Next i
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
CfgName = swChildComp.ReferencedConfiguration
Debug.Print sPadStr & "Component name: " & swChildComp.Name2 & ", Component ID: " & swChildComp.GetID
Debug.Print sPadStr & "Component name: " & CfgName
'-----------------------------------Start Standard INCH Parts---------------------------------------
If swChildComp.Name2 Like "*INCH-9752*" Then
FileName = "D:\Inch\INCH-9752-15665.sldprt"
If swChildComp.Name2 Like "*INCH-9566*" Then
FileName = "D:\Inch\INCH-9566-15756.sldprt"
'-----------------------------------End Standard INCH Parts---------------------------------------
Debug.Print "Replacement component = " & swChildComp.Name2
Debug.Print "All instances of old component replaced? " & bRet
TraverseComponent swChildComp, nLevel + 1
Next i
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Set swConfMgr = swModel.ConfigurationManager
Set swConf = swConfMgr.ActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
'Debug.Print "File = " & swModel.GetPathName
If swModel.GetType = swDocumentTypes_e.swDocASSEMBLY Then
TraverseComponent swRootComp, 1
