Hi all, I'm trying to made a Vb.net code that should import an model and update some equation dimensions.
This is the first time i'm using VS with SW api. So i really can't understand what I'm doing wrong .
I have added "SldWorks.dll" and "SwConst.dll" to the project references, then i added the code :
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
(here i also tried with "Imports SldWorks instead SolidWorks, but nothing)
VS is getting and warning saying me that the imports are unnecessary, so i tryied to continue by starting Solidworks and open a part with this code :
Function ModelParts()
Dim Part As SldWorks.IModelDoc2
Dim swEquationMgr As SldWorks.EquationMgr
Dim Options As Integer
Dim Errors As Integer
Dim Warnings As Integer
Dim longEquation As Long
Dim boolstatus As Boolean = False
Dim longstatus As Integer = 0
Dim longwarning As Integer = 0
Dim app As String = ""
SwApp = CreateObject("SldWorks.Application")
SwApp = New SldWorks.SldWorks()
Part = SwApp.OpenDoc6(WorkPath & "\test.sldprt", 1, 0, "", longstatus, longwarning)
swEquationMgr = Part.GetEquationMgr
If swEquationMgr Is Nothing Then ErrorMsg(SwApp, "Failed to get the equation manager of file " & "test.sldprt")
STOP
longEquation = swEquationMgr.SetEquationAndConfigurationOption(0, """A""=1000", SwConst.swInConfigurationOpts_e.swAllConfiguration, Nothing)
swEquationMgr.EvaluateAll()
Part.EditRebuild3()
boolstatus = Part.Save3(Options, Errors, Warnings)
If longEquation <> 1 Then ErrorMsg(SwApp, "Failed to modify the dimension " & "A")
SwApp.ExitApp
SwApp = Nothing
Return 1
End Function
When i reach program break at "Stop", i still don't have Solidworks opened, but if i check on Task manager, I can see it running on processes list.
Can someone help please, I really can't uderstand what's the problem. For now seems a problem with the references.
If need more info : I'm using Solidworks 2016 - Visual Studio 2010 (Net Framework 4.5.2).
