I've modeled a solid body (as a revolution with some later extruded cuts). My goal is to laser-cut the individual layers of this shape and then secure them together to build the full shape. I've done fabrication of this variety before, but generally I have only needed a few layers for the particular projects I was working on. In this case, I expect to need 60+, so manual production of these designs isn't practical.
I'm looking for a way to use SolidWorks to generate the individual cross-sections with as little manual intervention as possible. Preferably, I'd choose a plane and specify an offset/count and be able to produce either individual parts or raw sketches in some form for each step in that progression. Is there an existing way to do this in SolidWorks 2016? Might it require scripting?
Hi Kaelin,
I hope below explanation helps.
Draw sketch consisting of lines. These lines represent layers. Split your Part body using split option.
After you split it'll create a multi body part.
After splitting, you can choose to create an assembly from these multi-bodies so that SW will generate part file for each body (~ layers).
You can also choose to create configurations such that only one body is activated while the rest are deleted. It can be done using #TASK in one click.
