Serial number on data card should not increment after copying or adding file in vault.
Question asked by Hrishikesh Shirsikar on May 23, 2017
Latest reply on May 23, 2017 by Jeff Sweeney
Ok folks. I have Part & assembly data cards where I have linked variable to serial number. When I add a new Part/assembly file or copy it in vault from the outside., after copying data card shows the incremented value for the serial number even if I don't check-in a file. So my requirement is serial number should not be incremented by just adding or copying the file. It should be incremented only after check-in of a file.
Reason for this is: Suppose user adds a file and delete it without checking then after adding 2nd file it will take incremented value. So the previous record will not be found in the vault.
