8 Replies Latest reply on May 24, 2017 4:57 PM by Peter Brinkhuis
    MACRO TO CHECK INTERSECTION BETWEEN TWO COMPONENTS IN ASSEMBLY
    Korbi Anis
      Hello brothers , I wanto to know how can I check the intersection between to components in assembly after add mates . thanks in advance
        • Re: MACRO TO CHECK INTERSECTION BETWEEN TWO COMPONENTS IN ASSEMBLY
          Dennis Dohogne
          If you mean Interference then just select the parts and go to Tools -> Evaluate (near the bottom) -> Interference Detection.
            Christian Chu
            Use SW build-in Interference Detection - see below image
              Korbi Anis
              thank you very much for you answers. I tried it and it works fine . are there a macro to check interference between parts in assembly ? I want to automate this !!
                Korbi Anis
                I tried to write a macro to check if there are an interference between two components in assembly but at last I cannot display the result if there are interference or not !
                Option Explicit
                    Dim swPart1 As SldWorks.PartDoc
                    Dim swPart2 As SldWorks.PartDoc
                    Dim swComponent1 As SldWorks.Component2
                    Dim swComponent2 As SldWorks.Component2
                    Dim bValue As Boolean
                    Dim swBody1 As SldWorks.Body2
                    Dim swBody2 As SldWorks.Body2
                    Dim swBodyCopy1 As SldWorks.Body2
                    Dim swBodyCopy2 As SldWorks.Body2
                    Dim vBodies As Variant
                    Dim swModeler As SldWorks.Modeler
                    Dim vFaces1 As Variant
                    Dim vFaces2 As Variant
                    Dim vFace As Variant
                    Dim swFace As SldWorks.Face2
                    Dim vEdges As Variant
                    Dim vEdge As Variant
                    Dim swEdge As SldWorks.Edge
                    Dim swVertex1 As SldWorks.Vertex
                    Dim swVertex2 As SldWorks.Vertex
                    Dim vPoint1 As Variant
                    Dim vPoint2 As Variant
                    Dim swTransform1 As SldWorks.MathTransform
                    Dim swTransform2 As SldWorks.MathTransform
                    Dim swInverseTransform As SldWorks.MathTransform
                    Dim swRelativeTransform As SldWorks.MathTransform
                    Dim swMathPoint As SldWorks.MathPoint
                    Dim swMathPointTransformed As SldWorks.MathPoint
                    Dim swMathUtility As SldWorks.MathUtility
                    Dim lIdx As Long
                    Dim lNumEdges As Long
                    Dim lCoord As Long
                    Dim lEpsilon As Double
                    lEpsilon = 0.000000001
                    ' Connect to SOLIDWORKS
                    ' Get modeler
                    Set swModeler = swApp.GetModeler
                    ' Get Math utility
                    Set swMathUtility = swApp.GetMathUtility
                    ' Get active document
                    Set swModel = swApp.ActiveDoc
                    ' Select first component
                    Set swComponent1 = swModel.SelectionManager.GetSelectedObject6(1, -1)
                    ' Select second component
                    Set swComponent2 = swModel.SelectionManager.GetSelectedObject6(1, -1)
                    ' Get transform for each component
                    Set swTransform1 = swComponent1.Transform
                    Set swTransform2 = swComponent2.Transform
                    ' Get document for each component
                    Set swPart1 = swComponent1.GetModelDoc
                    Set swPart2 = swComponent2.GetModelDoc
                    ' Get bodies for first component
                    vBodies = swComponent1.GetBodies2(swBodyType_e.swSolidBody)
                    Set swBody1 = vBodies(0)
                    ' Make a copy for boolean operations
                    Set swBodyCopy1 = swBody1.Copy
                    ' Get bodies for second component
                    vBodies = swComponent2.GetBodies2(swBodyType_e.swSolidBody)
                    Set swBody2 = vBodies(0)
                    Set swBodyCopy2 = swBody2.Copy
                    ' Move bodies to their correct position
                    ' Apply transform
                    bValue = swBodyCopy1.ApplyTransform(swTransform1)
                    bValue = swBodyCopy2.ApplyTransform(swTransform2)
                    swModel.EditRebuild3
                    bValue = swModeler.CheckInterference(swBodyCopy1, swBodyCopy2, True, vFaces1, vFaces2, vBodies)
                    Peter Brinkhuis
                    First of all, what's with all the variable declarations? You are only using 14 variables. You can even bring that down by using arrays so you don't have to create two variables every time. Just do something like Dim swmodels(1) as ModelDoc2 to create an array with maximum index of 1. Since they start at zero, you have two items in your array.
                    Are you setting both component 1 and 2 as the same selected component?
                    To print some text when you are writing and debugging a macro, you can use Debug.Print("print this text"). You can combine it with other string variables Debug.Print("print this text" & stringVar1) or doubles (convert it to a string first via Cstr(doubleVar1)). In production, you could use the message box msgbox("print this text"). You can pass some more parameters to set the title of the message box, the types of buttons etc.
