DSDavid Shealey22/05/2017
I have a rather complicated mirrored part, but on the drawing I cannot properly dimension a hole. In the original it is dimensioned with a limit tolerance, but I cannot do that on the mirrored part. If I put in a hole callout, there is no value parameter for the diameter that can be picked, putting a limit tolerance in does nothing. I tried just putting in a note, but see no way to do the limit tolerance in a note.
Searching for a solution, see that this has been a problem for YEARS! Now on SW 2016 SP5.
Is there any way to work around this VERY OLD issue?
