Get part number used in BOM
Question asked by Xavier Rodríguez Nieto on May 22, 2017
Latest reply on May 22, 2017 by Xavier Rodríguez Nieto
When you insert a BOM in a drawing, one of the parameters you can show is the "PART NUMBER" (probably the most important), the value for the "PART NUMBER" is determined in the configuration of the component and it can be the document name, the configuration name or any other manually-written value. You can also choose to link the part number to the sub-assemblies or not:
The question is: how can I get the final value assigned to the parameter "PART NUMBER"? I found this in the API help:
2016 SOLIDWORKS API Help - Change Configuration Properties Example (VBA)
_________________________________
Function BOMPartNumber(config As SldWorks.Configuration, document As SldWorks.ModelDoc2) As String
    Select Case config.BOMPartNoSource
    Case SwConst.swBOMPartNumberSource_e.swBOMPartNumber_ConfigurationName
        BOMPartNumber = config.Name
    Case SwConst.swBOMPartNumberSource_e.swBOMPartNumber_DocumentName
        BOMPartNumber = document.GetTitle
    Case SwConst.swBOMPartNumberSource_e.swBOMPartNumber_UserSpecified
        BOMPartNumber = config.AlternateName
    Case SwConst.swBOMPartNumberSource_e.swBOMPartNumber_ParentName
        Dim parentConfig As SldWorks.Configuration
        Set parentConfig = config.GetParent
        If parentConfig.BOMPartNoSource = SwConst.swBOMPartNumberSource_e.swBOMPartNumber_ParentName Then
            BOMPartNumber = BOMPartNumber(parentConfig, document)
        Else
            BOMPartNumber = parentConfig.Name
    End Select
End Function
Isn't there any more simple way to do the same? Something like a property or method in the "IModelDoc2" object or any other. It's strange that you can't access this property directly, taking into account the importance of that parameter in the production chain.
