I have done something to my .drwdot (or maybe .stddrt? still not clear about where what is stored but I think it is the .dwrdot.) so that when I start a drawing the tab at the bottom for that first sheet says "Sheet 1", but adding more sheets starts with "Sheet1", and then "Sheet2", "Sheet3", ....
How do I fix that?
Also I have a possibly related question. I make some fab drawings where I bring in an assembly and I use custom properties from the assembly model to fill in fields in the first sheet of the drawing. I then use the next sheets to bring in parts from the assembly model and do detailed dimensioning of those parts on each sheet. I want the custom properties of the assembly that I placed on the first sheet to fill in the custom properties that are on the following sheets. I know there is a document setting Options > Document Properties > Drawing Sheets > Multi-Sheet Custom Properties Source and I have it checked. It still doesn't grab the custom properties from the first sheet. Might be related to the above problem.
Steve Krause
Change your template back to Sheet1 (no space).
As for your custom property issue, In the Sheet Properties dialog, under "Use custom property values from model shown in:", select the view that contains the model you want to take the custom properties from.
