I am constructing an Oldham Coupling, the remainder of the assembly requires copying the object, and then turning it 180 degrees so that
the original object is attached to a mirrored version. I can't figure out what command will work to turn the copied object 180 so that the assembly will fit together.
Any advice would be greatly appreciated!
Hello Michael,
You've posted the Assembly file, but it won't open without the Part files. For the future, if you'll use the Pack and Go feature to place the Assembly and all it's Part files into a zip folder and post that we'll be able to open it. Now, with that being said, I'll try to help anyway. In Assemblies, there is a Mirror Components command, which will do just what it says. Select a Plane or flat surface to place the second Part. If you don't get the anticipated results in the yellow preview then be sure to click on the small blue arrow at the top of the Feature Manager to get more options (including one that will create a mirror version of the Part, if necessary).
Please reply back to let us know if that works for you, or if you need more help.
