I have a part called "Rev 1 Tool" (model and drawing)
I made a copy , saving it as "Rev 2 Tool" (model and drawing) .
"Rev 2 Tool" drawing is associated with "Rev 1 Tool" model. When I make modifications to "Rev 2 Tool" model, they are not updated in "Rev 2 " drawing.
How do I change association of "Rev 2 tool" Drawing so it reflects the changes made to "Rev 2 " model?
Using a different configuration will not work in this case.
Close the Drawing, then go to File > Open. Browse to the Drawing. Select it, but don't open it. Click on the References button. That will take you to a box where you can change the reference.
...or, with the Drawing open, right-click on a Drawing View of your model and select "Replace Model". That option was introduced within the last couple of years, so if you're using an older version you might have to use the first method above.
