Lines showing thru in display style shaded with edges and not in shaded, see snip.
Can anyone help, this is driving me crazy?
It looks like the component (or it's surfaces) in front is set to transparent. Is that possible?
No, nothing is set to transparent. The cover is set to hide, but the lines will show through even when the cover is at show. All of my large assemblies are doing this. It doesn't happen if I open a sub assembly or with individual parts.
Graphic Card Issue.
The card is toast?
You could say that after you spread the butter and jam
Check your SX RX and do a diagnostic test
John Stoltzfus wrote: Graphic Card Issue.
That was going to be my second guess.
Thanks, I'll check it.
