ive never seen this one before and havent been able to find anything about it, all my dimension seem to be in 3d air while im editing a 2d feature, i am also not able to double click on the dimensions to edit.
I highly doubt it either, however there comes a time where you keep grasping for straws in hopes you draw the short one - if it's just the one part it could be corrupt - but it could be a rebuild issue as well, I've seen crazy stuff happen with circular rebuilds..
If all your settings come out ok, now my question is how was this part modeled, Top Down or Bottom Up? Are there any external references or sketch relations to another component in the main assembly???
it must be corrupt, i recently had a model that i couldnt open this week also and had to restore previous version, could my computer be corrupting these files?
I'm not sure if this applies but I had a single part model today where I could NOT turn off the feature dimensions without turning off ALL annotations. No matter what combination of settings that I chose, the dimensions would not disappear. Turning off all annotations resulted in a loss of all cosmetic threads which I didn't want to happen.
The solution? I rebooted my computer.
I wasted a good half hour researching the problem and trying different solutions when all my computer needed was a good flushing.
Like I said, not sure if this applies but I thought I'd share.
If you turn this feature off, does it still do it?
