4 Replies Latest reply on May 18, 2017 4:46 PM by Menno Geefshuysen
    combine ''view'' items with a macro button (on/off)
    Menno Geefshuysen
      I have a macro that was a solution on a problem I had yesterday, the problem for me was to add a if command in a macro.
      If Command Macro
      Solution:
      'This macro will toggle the user setting for selection of hidden edges in HLV &
      'wireframe modes.
      'Precondition: A currently running session of Solidworks.
      'Postcondition: The user setting for hidden edge selection in HLV/wirframe _
                      has been toggled and the updated setting can be seen in _
                      the status bar.
      Dim swStatus As SldWorks.Frame
      Set swStatus = swApp.Frame
      ' Case Selection of hidden edges - Allow selection in wireframe and HLV modes
      If swApp.GetUserPreferenceToggle(swUserPreferenceToggle_e.swEdgesHiddenEdgeSelectionInWireframe) = 1 Then
          swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swEdgesHiddenEdgeSelectionInWireframe, False
          swStatus.SetStatusBarText "Hidden Edge Selection = OFF"
      Else
          swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swEdgesHiddenEdgeSelectionInWireframe, True
          swStatus.SetStatusBarText "Hidden Edge Selection = ON"
      Now I want to combine the view options show/hide Origin and Coordinate system the same way, with the same macro structure.
      what I captured when recording a macro was:
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set Part = swApp.ActiveDoc
      boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayCoordSystems, True)
      with this information I think I can go proceed to investigate the difference between those and get to know more about the coding.
      Please help me out Solidworks Masters of the World!
