hello i have recently been brain storming on a vibration grommet / mount that could work in sheet metal . any input on past experiences would be great
yes, ive been looking at those i guess my application is a bit unique i am attempting to suspend a sheet metal base plate in a box giving the components on the base plate less vibration.
Here is a version that could be mounted to anything:
Product Search - IMAO CORPORATION
https://www.imao.co.jp/files/on-cat/pdf/en/tc-viby-e.pdf
If you want to order from them, their only distributor in the states is Fixtureworks.
Workholding Solutions, Equipment & Products - Fixtureworks - Fixtureworks
Check out this stuff, it's not a grommet but it's properties are amazing. Santoprene is the name.
After I posted I saw you added a picture, I assume your using a spacer in the groove to accommodate a larger grommet or bolt. I have always found that they became less resilient as they became larger. Always equals two times in this example.
There are a whole bunch of them here:
https://www.mcmaster.com/#vibration-damping-grommets/=17o1yvl
