I have a bunch of .dxf files I am about to convert to Part files.
This mean every geometry is contained within one sketch - including the text that every .dxf file have.
The text need to be engraved in the final part, so I have to keep this feature on the part.
First I make a Boss-Extrude of the outside geometry, and then a Cut-Extrude of the text - but this takes a while as I have to click every single geometry.
Is there a easier way to do this ?
If you are "sharing" the one sketch for the basic extrude and the engraving, when you get to the engraving step, you can click on the sketch in the feature manager tree, then click on convert entities - it will grab everything, so just delete the outside lines, and you will have all of your text ready to engrave.
todd
edit - I guess I didn't "share" the sketch, I created a new sketch, clicked on the original sketch, clicked convert entities, deleted the outside lines, did the engraving.
right steps, wrong verbiage . . .
