FSFoad Sojoodi Farimani17/05/2017
Following the discussions here and here, I'm trying to make a closed loop 2D/3D sketch using the "equation driven curves". However when I want to make aclosed curve it does not work. for example when I put :
t from 0 to 2*PI
x=sin(t)
y=cos(t)
I get the error below:
It is disappointing, because other software packages such as PTC Creo, Autodesk Inventor and even open source ones like FreeCAD, have this feature!
the reason, I need a closed loop equation driven curve is that if I use only an instance of my periodic function and then use a feature pattern, then later when I change the number of instances there will be an error.
