When I click "Install Now", I get the following errors:
"The user needs the SQL permission 'CREATE ANY DATABASE'."
I click OK...
"The user needs the SQL permission 'ALTER ANY LOGIN'."
I saw this same question posted here
Unable to install V2016 - user needs sql permission 'CREATE ANY DATABASE'. Help!
with 800+ views and no responses, which is highly disconcerting. I tried installing sqlmanagementstudio_x64_enu from the install folder but it didn't change anything. What should I do?
Newly upgraded PC to Windows 10 LTSB 2016 x64
You might want to try move the post to the Electrical forums as it is a problem with installing SOLIDWORKS Electrical. Can you please take a screenshot of the Electrical options you are using to install? Are you trying to create a new SQL instance or modify an existing one?
