Conjugate heat transfer between coolant and two solids
Question asked by Admir Jonuz on May 16, 2017
Latest reply on May 19, 2017 by Siavash Khajehhasani
Hello all
I am trying to simulate the conjugate heat transfer between a fluid in a pipe (acting as the coolant) and two solid bodies as illustrated in the attached figure,. The figure illustrates the resitances in the system:
1. Coolant (convective cooling)
2. Solid outer aluminium cape with a thickness of 7mm
3. Solid 0,5mm thick surface heat source with a fixed inlet temperature
The modeling is performed with the following settings:
- External
- Conjugate heat transfer in solids
- Timedependent
- Gravity
I am interested in estimating the outlet temperature of the (3.) solid and the cooling rate across the 180 [deg] circumference of the pipe.
Is a constant heat flux on the inlet of the solid a possibility or do one need to treat the (3.) solid as a "fluid" subdomain assigning a inlet flow with fixed temperature?
