AHAlex Hartung16/05/2017
Hello all,
I am currently writing a BOM Macro that will take a model and auto-generate an entire BOM based on our specified template. The end results include:
     1. Cover Page with Isometric model View of the part placed in the center of the page and scaled appropriately.
     2. BOM sheet with Same model view inserted in the bottom right section and scaled appropriately.
     3. Bill of Materials Table inserted into the BOM page using the model view previously inserted in the bottom right.
Additional features:
     Often BOM are very long and for the specific sheet size and format I am using, 14 items is often the cut-off I want for the BOM table per sheet. With that being said, I am using the horizontal auto-split method to split the BOM table into an array of Tables that each contain 14 items until the last member which will have the remainder. The ideal format will thus be an extra BOM sheet for each index in the BOM table array.
The problem is... I cannot figure out how to manipulate and select the specific sections of the BOM that were cut up by the auto-split. I have tried using all kinds of different objects like ModelDoc to use the .EditCut and .Paste features to Cut and Paste the specific sections I am trying to move into each new sheet. I have done this successfully with making enough copies of the BOM Sheet that match the (# of items in BOM Table / 14). The reason I don't want to insert the BOM table into the BOM Sheet and then copy and paste as many times as I want and then delete the specific rows outside my range is because then I end up with a bunch of Bill of Materials Tables rather than just 1. With more than 1, they will not auto-update properly and thus does not give me the functionality I am looking for.
If anyone could please shed some light on this, I would greatly appreciate it!
P.S. I have attempted to record a macro as I cut and paste the sections I am looking for and ultimately the results give me something like Part.Extension.SelectByID2("DetailItem456@BOM", "TABLEANNOTATIONS", blah blah). But this does not make sense where they would get these "DetailItem456" and when I do multiple selections one after another for each new section of the BOM Table, it always gives me "DetailItem456" as the selection name. This simply does not seem correct. When I implement in a greater schema, it ends up copying and pasting the sheets and the BOM table entirely.
Thanks in advance! I have provided the brief section I have written so far that seems to be functional with the section I am trying to work on commented out.
Dim swApp           As SldWorks.SldWorks
Dim swModelDoc      As ModelDoc2
Dim swDrawingDoc    As DrawingDoc
Dim swView          As SldWorks.View
Dim sheetNames      As Variant
Dim documentTitle   As String
Dim drawingTemplate As String
Dim sizes           As Variant
Dim scaleratio      As Integer
Dim count           As Integer
Dim Part As Object
Dim swModel As ModelDoc2
Dim boolstatus As Boolean
    '***Get the SldWorks app, Model, and Doc
    Set swModelDoc = swApp.ActiveDoc
    documentTitle = swModelDoc.GetTitle
    drawingTemplate = swApp.GetUserPreferenceStringValue(swFileLocationsDocumentTemplates)
    drawingTemplate = "F:\Dropbox (OceanAero)\MECHE\SOLIDWORKS_FILES\SOLIDWORKS_TEMPLATES\DRAWINGS\TEMPLATE_DRAWING_BOM_DEFAULT_SOLIDWORKS_V01R08.drwdot"
    sizes = swApp.GetTemplateSizes(drawingTemplate)
    If IsEmpty(sizes) Then
        MsgBox "Failed to get valid template sizes."
        Exit Sub
    ' Create a new Drawing
    Set swDrawingDoc = swApp.NewDocument(drawingTemplate, sizes(0), sizes(1), sizes(2))
    sheetNames = swDrawingDoc.GetSheetNames
    Dim status As Boolean
    Dim Position As Variant
    Dim retVal As String
    Set swView = swDrawingDoc.CreateDrawViewFromModelView3(swModelDoc.GetPathName(), "*Isometric", 0, 0, 0)
    swView.SetDisplayMode (swViewDisplayMode_ShadedWithEdges) ' Not working for some reason
    Position = swView.Position
    Position(0) = Position(0) + 0.12
    Position(1) = Position(1) + 0.16
    swView.Position = Position
    swView.ScaleDecimal = 0.1
    swDrawingDoc.ActivateView ("Drawing View1")
    swView.GetDisplayEdgesInShadedMode
    swDrawingDoc.ViewDisplayShaded
    swDrawingDoc.ViewModelEdges
    swDrawingDoc.EditRebuild
    swDrawingDoc.ActivateSheet sheetNames(1)
    Position(0) = Position(0) + 0.3
    Position(1) = Position(1) + 0.034
    swView.ScaleDecimal = 0.02
    swDrawingDoc.ActivateSheet ("BOM")
    Set swModelDoc = swDrawingDoc
    status = swModelDoc.Extension.SelectByID2("BOM", "SHEET", 0.09205356547875, 0.10872368523, 0, False, 0, Nothing, 0)
    Dim currentsheet As Sheet
    Set currentsheet = swModelDoc.GetCurrentSheet
    swModelDoc.EditCopy
    For i = 0 To 3 ' This will be adapted to the # of splits that are done for the BOM table
        swModelDoc.ActivateSheet (currentsheet.GetName)
        status = swModelDoc.PasteSheet(swInsertOption_MoveToEnd, swRenameOption_Yes)
    Next i
    '***Get the first View
    '***Set the full path to the desired BOM template
    '***alternatively an empty string will use the default template
    Dim TemplatePath As String
    TemplatePath = swApp.GetUserPreferenceStringValue(swFileLocationsBOMTemplates)
    TemplatePath = "F:\Dropbox (OceanAero)\MECHE\SOLIDWORKS_FILES\SOLIDWORKS_TEMPLATES\BOM\TEMPLATE_BOM_DEFAULT_SOLIDWORKS_V01R08.sldbomtbt"
    '***Set the arguments for InsertBomTable2
    Dim UseAnchorPoint As Boolean
    UseAnchorPoint = True
    Dim X As Double
    X = 0#
    Dim Y As Double
    Y = 0#
    Dim AnchorType As Long
    AnchorType = swBOMConfigurationAnchor_TopLeft
    Dim BomType As Long
    BomType = swBomType_PartsOnly
    Dim Configuration As String
    Configuration = ""  'Empty string uses the configuration referenced in the view
    Dim TableTemplate As String
    TableTemplate = TemplatePath    'Full path to the template required
    '***Insert the BomTableAnnotation
    Dim BomTableAnnotationObj As SldWorks.BomTableAnnotation
    Dim swTable              As SldWorks.TableAnnotation
    Dim swTableArray()          As SldWorks.TableAnnotation
    Set swView = swDrawingDoc.ActivateView("DrawingView2")
    Set BomTableAnnotationObj = swView.InsertBomTable2(UseAnchorPoint, X, Y, AnchorType, BomType, Configuration, TableTemplate)
    Set swTable = BomTableAnnotationObj
    count = swTable.TotalRowCount / 14
    swTableArray = swTable.HorizontalAutoSplit(14, swHorizontalAutoSplitApply_Continuousely, swHorizontalAutoSplitPlacementOfSplitTable_BelowLastSplit)
    Debug.Print count
    Set Part = swApp.ActiveDoc
    For i = 1 To UBound(swTableArray)
        status = Part.Extension.SelectByID2("DetailItem456@BOM", "ANNOTATIONTABLES", 1.98546152455048E-03, -8.21423383205782E-02, 0, False, 0, Nothing, 0)
        Part.EditCut
        swDrawingDoc.ActivateSheet ("BOM(" & i & ")")
        Part.ViewZoomtofit2
        Part.Paste
    Next i
    '***Update to show the BOM feature in the Feature Manager Tree
    swDrawingDoc.FeatureManager.UpdateFeatureTree
