I have a simple sheet metal part that has a 88deg bend. I created it using a flat pattern and Sketched Bend at 88deg. I want to use a Configuration to show it in the installed state at 90deg. I tried to do this with adding Manual Configuration and then modifying the angle in the Sketched Bend feature. This did changed both configurations (default, and as installed). Sketched Bend does not have an option for "this configuration only".
Any ideas on how I can do this?
- Derek
Add config and double click sketch bend, then double click angle dim change to this config and change dim.
