I would like to create a macro which saves an active assembly as separate dxf files of each of the standard views, but not current or ISOs. To do this manually, I have to first save the assembly as a part, then save the part as a dxf and check some boxes. The dxf folder is a sub folder of the active file location called "SW DXFs". I have found two macros, both written by Deepak Gupta, but I'm having trouble combining them as I have a very small knowledge of VBA.
Save Assembly as Part:
Save part to DWG:
https://forum.solidworks.com/message/436713#436713#436713
Can anyone help me or give me a step in the right direction?
Thanks in advance,
Rob
Set up a drawing template with no title block but multiple sheet. Insert a pre-defined view on each sheet like front, top, etc.
Now create drawing using that template and then save as separate DXF sheets.
