I am trying to model a quip toothbrush..I am not getting how to model the middle part which involves a delicate surface feature. I tried using sweep with guide curve but couldn't do it. I have attached both my model and the toothbrush image. Kindly help
This is what I think the handle should be from the pictures. I just made the whole thing the same diameter then made a cut across.
Note: I would double check the size of your brush I am seeing 4.3097" for the diameter, that seems a bit large.
For my handle I just used random sizes for, dia. length, cut. not knowing what they should be.
