DEDavid Edwards17/12/2008
I'm trying to edit the calloutformat.txt file and I'm a little confused. There are two files. One is calloutformat.txt and the other calloutformat_2.txt. calloutformat.txt states at the top "NO-NUMBER-OF-INSTANCES" while the other doesn't have this stated. Are both of these files used based on the number of holes used in the HW? I see no num_inst to call out the number of instances in either file.
What I want to do is format the hole callouts so that I get something similar with the (X num_inst) at the end of the callout. I'm not really sure what I need to change in the strings to move the num_inst to the end. It almost seems to be embedded within another command.
Ø.250 THRU (X4)
EDIT: fixed num_inst as stated below
