I posted a similar question in the Task Scheduler forum and
never received an answer so I thought I would try here. I would
like to be able to use task scheduler to set up several renderings
to run after I leave work. The problem I have is that after the 1st
rendering is completed Task Scheduler does not go on to the next
one on it's own. When I come into work the next morning solidworks
is open, with no model open. It has completed one render file, but
no others in the queue. If I close the solidworks window manually
it will then go on to the next task on the list. Has anyone else
experienced this? Is there any way around it? Are there other ways
to set up multiple renderings to be run while my computer would
otherwise be idle? Any help would be greatly appreciated.
